Rim Powdercoating
Dr. Frankenstein
Rim Powdercoating
Post by Dr. Frankenstein » Sat Jun 19, 2010 4:19 pm
The rims on my 1964 CA77 are trashed; after much contemplation, I have pretty much decided to go with powdercoating them a bright, almost chrome-like powdercoat from Powder Buy The Pound. My question is, what do I have to do to pre-treat them? The chrome is flaking off, and they're pitted and VERY rusty - would just bead-blasting them and then powder coating them work, or do they have to be dipped to ensure a proper adhesion?
-John
Buck
Post by Buck » Sun Jun 20, 2010 8:19 am
John, sandblasting is usually all that is required for prep and depending on how deep the pitting goes it may take a few coats to fill them in for a decent finish. Do you have an S90 that I worked on a while back when you lived in Atlanta? Buck
Post by davomoto » Sun Jun 20, 2010 4:06 pm
I wopuldn't put flaking chrome parts in a bead blaster! It will plug up the air passages . Sand blasting and sanding out to do the trick.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
interpon
Post by interpon » Sat Aug 13, 2011 8:11 pm
Grit blast
Powder primer
Sand to remove pits
Chrome powder ten you must clear it to last..
Bad part is te clear really knocks the chrome look down..
