                    Steering head bearings
				Hoosier Tom
				MBellRacing
- h305 Moderator
Tom, the instrument cluster issue isn't definitive in much the same way that the year tag on the harness can be inaccurate. The Type-Ic instrument ('63-issue) was the first with hi-beam indicator; but my first CB77 was a genuine '64 -- CB77-40XXXX -- and was fitted with a Type-Ib with no hi-beam ind. That was UK, mind you.Hoosier Tom wrote:That speedo is no later than a '62 (no high beam indicator).
				Hoosier Tom
- h305 Moderator
Interesting, Tom. Do either have the crankcase breather on the back of the upper casing? And how do they compare with the '61-'62 model year changes that I listed a couple of posts back?Hoosier Tom wrote:Steve,
I know what you mean. Both of my '62s have no high beam indicator. I had 2 '63s and 1 '64 and they all had the high beam indicator (here in the states).
Both of my '62s have the lock bolt for the camchain tensioner on the left side.
The VIN numbers indicate 1963.
Tom
The Forum is the only place we now have to share, collate and maintain knowledge. I'm putting together a model-year database, but only for '65-'67; we're able to pinpoint model-years >'64, but '65> Honda just issued a numerically-ascending range of 7-digit frame numbers with no apparent breaks.
Thanks for keeping up the responses.
				Hoosier Tom
				Hoosier Tom
Steve,
My bikes
Speedos no highbeam, Hm logo Nippon Seike, mounted in bucket with screws
Both Stanley D2R short lenses
Both thicker peg mount brackets
No case breather on either
TLS drums
grey cables
Cheers- Tom
													My bikes
TLS drums
grey cables
Cheers- Tom
