more pic's of the water cooled cb72 and questions
thumper2146
Post by thumper2146 » Wed Sep 22, 2010 12:51 am
yep it's a crack small but i will post a pic in the morning
thumper2146
crack pic's
Post by thumper2146 » Wed Sep 22, 2010 10:38 pm
well here are two shots of the crack what do you guys think i should do?
A. nothing
b. strip the engine and sell the 360 crank with the head for someone that wants one.
c. have it welded up
thanks
James
Re: crack pic's
Post by LOUD MOUSE » Thu Sep 23, 2010 4:19 am
Actually an easy fix.
Remove the chip.
make sure the knock/locater pin is down into the bearing as far as it should be.
Apply enough J.B. Weld to hold the chip with a little extra on the outside. ...............lm
thumper2146 wrote:well here are two shots of the crack what do you guys think i should do?
A. nothing
thanks
James
thumper2146
Post by thumper2146 » Thu Sep 23, 2010 11:49 pm
thanks LM . all is not lost then
James
mike horvath
Post by mike horvath » Fri Sep 24, 2010 1:16 am
Ed your crackin me up! I did that very thing in Thumpers picture just recently. Don't know how...I was being careful, but things happen. Used JB weld over and into the chip, then used a punch to drive the chip back down. But also a bit of it into the guide pin hole base but not enough to keep the pin shoulder from staying high. then I got real smart and beveled the guide pin hole, applied some heat and oil resistant compound and slid it in to the exact depth. Maybe overkill but I was concerned it would leak. Thanks for the lesson. I think I did it as right as I could.
And it looks as though the drive sprocket retainer is welded on in those pics. Good luck Thumper.
Mike
thumper2146
Post by thumper2146 » Sat Sep 25, 2010 7:32 am
sprocket is not only welded but it is also welded to a extension shaft of a few inches to kick it out some
thumper2146
inside the trans pic's
Post by thumper2146 » Thu Oct 14, 2010 11:06 pm
Something does not look right this is what i found when i took the cases apart:)
James
clutch  direct drive a little machine work ?
