slide valve, pin removal
Can anyone help me with removing the carb slide and pin from the top of the carburetor ('63 honda ca77)?
float pin removal
Thanks for the info about the slide. I got it and managed to not lose a spring. How do I go about removing the ping that holds the floats to the upper part of the carb?
float pin removal
This thing is so gummed up! The entire lower bowl is covered in salts and the float itself is actually black. Does this pin come out in one direction (as shown on the parts fiche)?
Good idea to soak it as Brewsky suggested since it is so corroded in there. In extreme cases I have used a small dremmel cut off wheel, and cut the pin between the float and the arms. It's easier to support the arms that way if you have to knock the pin out.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
