Starter planetary gear grease?
Jethro
Post by Jethro » Mon Nov 01, 2010 10:10 pm
Hi I wasn't sure where to post this but here goes. I just pulled the starter drive sprocket end off of my starter so I could clean it and prep for paint. When I pulled it off, I noticed the grease inside the planetray gearing was pretty dried up and thick. Does anyone know what type of grease is best used in this application? Jethro.
Jethro
Post by Jethro » Mon Nov 01, 2010 10:47 pm
So I found some stuff laying around the shop. MIL-G-21164C. About the same color, consistency, and smell. Only clean! I looked up some info on it and I think it will suit my starter fine. I suppose the gear grease in the starter should be relatively thick due to the stresses with those gears. Any thoughts? Anything better out there?
Post by LOUD MOUSE » Tue Nov 02, 2010 12:28 am
I use the black hi-temp wheel bearing grease. .........lm
Jethro wrote:So I found some stuff laying around the shop. MIL-G-21164C. About the same color, consistency, and smell. Only clean! I looked up some info on it and I think it will suit my starter fine. I suppose the gear grease in the starter should be relatively thick due to the stresses with those gears. Any thoughts? Anything better out there?
