I think carbs are made of ZAMAC an alloy of zinc aluminum, magnesium and copper.
Yes, zinc is one of the main ingredients,
Carb Cleaning With Vinegar
Sorry about the confusion. Carburetors are usually made from ZAMAK=Zinc+aluminum (%4)+magniseum (about %2.5) and copper(about %.025). It is a zinc base alloyed with other metals to make cleaner castings since pure zinc gets what is called "zinc pest" during casting. If you have Brit made carbs they are probably made from MAZAK, which has %.04 less pure zinc. NBD
Like I said carbs are made from zinc...
'61 CB77, '72 TC125, '72 CB350F, '73 CB350G, '76 CB400T, '79 XR80, '79 XS750 (850), '83 CB650S, '84 KDX250,'91 YZ 250
- Contact:
No, but when paying attention to the following points, it is save and harmless.
- get all brass parts out, especially the jets.
- do it in steps, 10 minutes to 15 minutes, then rinse with (warm) water to neutralize the vinegar.
- clean the carb after soaking in water, get all the dirt off with a toothbrush, and decide if it neccecary to do it again.
If you decided it is nice enough, rinse with water again, and dry with pressed air, especially the narrow holes.
Let it dry and buff it up with a dry cloth,
Or computer dust spray?
http://www.shopwiki.com/_Compucessory+A ... 4&s=207032
