Special removal bolt
djohns
Post by djohns » Mon Sep 18, 2006 11:14 am
Need help on the special left hand bolt used to remove the alternator rotor from the shaft. Anybody know the size and pitch. I can make one on the lathe if necessary. JIS or ISO on a 64 CA77? Also has anybody run across bulk wire with the same stripping scheme since my harnesses have many patches. Thanks
Hahnda
Post by Hahnda » Mon Sep 18, 2006 1:24 pm
Try using the rear axle. Thread it in and put a large srewdriver through the hole. A few taps of a hammer on the screwdriver handle in the correct direction and the rotor should be loose.
Kevin
djohns
Post by djohns » Mon Sep 18, 2006 3:39 pm
Thanks Hahnda. Looked left hand to me, but than again I was standing on my head when I looked at it.
kustommusic
Post by kustommusic » Mon Sep 18, 2006 9:39 pm
I thought it was the front axle!
Hahnda
Post by Hahnda » Mon Sep 18, 2006 10:28 pm
Nope. I'm 110% sure its the rear. Its what I used to remove my rotor. Front axle is to small.
djohns
Post by djohns » Tue Sep 19, 2006 11:27 pm
Rear axle it was. Worked it off the tapered shaft in 1/2 turn.
