Carb Rebuild - putting back together.
Sascha
Post by Sascha » Tue Nov 23, 2010 10:43 am
Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
brewsky
Post by brewsky » Tue Nov 23, 2010 1:00 pm
Sascha wrote:Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
As you look at the side of the carb with screws, one on the left (angled) is air idle mixture.
The one on the right is the idle speed screw.
Left screw..screw in till lightly seated, then back out 1 1/2 turns
Right screw does essentially the same thing as opening the throttle (actually sets how open it is when the hand throttle is closed)
Turn it in while observing the slide, and stop just when you can see the slide starting to move up.
Make sure you have the carb float set to 26.5mm before you re-install carb.
This applies to CA models with single carb.
marlin4622
Post by marlin4622 » Wed Nov 24, 2010 11:49 am
Sascha
brewsky,
are you suggesting that you adjust the carbs without the air intake hose on so we can see the inside of the carb?
also, you are referring to the needle slide ?
brewsky
Post by brewsky » Wed Nov 24, 2010 12:16 pm
marlin4622 wrote:
Sascha
brewsky,
No...just referring to the initial setting to start with,.....I do this before even putting the carb back on after cleaning.
Carb adjustment should be done with the engine up to operating temp and air cleaner attached.
Yes, I am referring to the slide...it's hard to see when the air cleaner is attached, so I adjust it before installation
marlin4622
Post by marlin4622 » Wed Nov 24, 2010 12:18 pm
nvm i just realized its for a ca carbs.. i am running cb77 pw26's
nrizvi
looking for the clip
Post by nrizvi » Thu Dec 02, 2010 4:07 pm
Hi I am looking for a carb clip which holds lower bowl of the PW22 carb. Also a rebild kit can some provide some info.
Thanks.
Post by davomoto » Thu Dec 02, 2010 5:22 pm
PM me , I have spare clips. Keyster kits are good for the gaskets, and the float needle and seat. Re-use the oroigional brass after cleaning everything really well.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
