torque specs
yogi64
torque specs
Post by yogi64 » Fri Jan 07, 2011 2:48 pm
i have just put new pistons and rings in and a valve job, but the book i have does not have any torque specs for the head, can anyone help, its a 1964 honda 305 dream, thanks yogi64
Post by davomoto » Fri Jan 07, 2011 4:01 pm
Hey Yogi, standard spec is 16 ft lbs if I remeber correctly. Most of us go2-4 ft lbs higher than that. I always retorque them after the engine has sat for 24hrs, and they always seem to need it. I guess that the gaskets settle in a bit after being torqued. This can be impossible to do on the inner bolts with the engine installed, so patience is required. Also, edit your location into your profile when you get a chance!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
yogi64
torque specs
Post by yogi64 » Fri Jan 07, 2011 4:38 pm
thanks alot Davo
Post by davomoto » Sat Jan 08, 2011 11:03 am
You're welcome!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
