Snakeoil wrote:
The following measurements are taken with a lever free play set at 15mm.
Dt = 17mm*
I'm not clear on your measurement. If the free play is 15mm and the total "Pull" (Dt) is 17mm then does that mean you only have 2mm of cable movement to actuate the clutch?
Actually, the 17mm is the figure I'm interested in. That should equal the amount of movement at the end of the cable connected to the Clutch Lifter. I have my motor on the bench now and I want to see how much my clutch is moving when disengaged (ya I know... I could have checked this when it was on the bike... I didn't). 17mm of movement on the Clutch Lifter will show me how much movement there is on the push rod and that is how much my pressure plate will move.
I too suffer from the "Sticky Clutch Syndrome". I have read just about everything there is here on this subject and have checked/tried all the recommended items and the problem still persists. It seems like it comes down to the thin film of oil between the plates.
tnx
George
