Air Filter Issues
francesca_you_betcha
Air Filter Issues
Post by francesca_you_betcha » Mon May 09, 2011 11:45 pm
So, I bought a 1967 cb77 that had lived in a barn for 25 years...
$1,200 later, I have a decently running, rough-around-the-edges machine.
My mechanic tells me that the air filters he put on it to get her running are making her run lean, resulting in a sort of sputtery ride.
My question: should I try to find "original" style air filters? Where should I look for these?
I see some nice looking repro parts out of Asia, but I'd love a recommendation.
Thanks!
cyclon36
Post by cyclon36 » Tue May 10, 2011 8:02 am
I'm guessing that since he's a mechanic that he's already adjust the air/fuel screw to it's limit? If that's the case, I'd rather go with larger jets than a more restrictive filter.
jleewebb
air filters
Post by jleewebb » Tue May 10, 2011 8:14 am
Cool, another superhawk in Austin. Maybe we can get a pack together for a ride sometime.
Retrobikes at http://www.olypen.com/retro/ has your repro air filters for a reasonable price. If you don't have original brackets, tubes, and springs, they're out there somewhere, a little harder to find.
Please don't ride too far with engine running lean, it can have catastrophic results.
How about some pix? --Lee Webb
'62 CB77. "It's a rider."
Re: Air Filter Issues
Post by LOUD MOUSE » Tue May 10, 2011 10:10 am
Welcome.
I live in Kerrville and may be of help.
In the 60's when these bikes were new even then there was a saying which is still true today.
"Your carb problems are in direct proportion to the miss-adjustment of your points"!
Ya can check the timing easily by following the procedure in the FAQ section to the left (Yellow info) and How I adjust my engine.
To just check timing all ya will need is 12 volt light as described.
Get in touch if ya think I can help. ..........lm
francesca_you_betcha wrote:So, I bought a 1967 cb77 that had lived in a barn for 25 years...
Thanks!
Dana01
Post by Dana01 » Tue May 10, 2011 2:10 pm
Welcome Francesca,
Ohio Cycle has inlet tubes and springs/clamps as well as repro. filter elements.
Good luck!
Dana
1966/7 CB-77 Red of course
MBellRacing
Post by MBellRacing » Tue May 10, 2011 10:28 pm
Wait, wait, wait? You have BETTER filters, your bike is running lean, and you want to change back to more restrictive filters instead of just rejetting? Por que?
