pwilke1 wrote:Just a heads up. I also tried the white wall paint before going with the inserts. Like you I painted them before mounting. However after having them mounted, much of the paint was stripped / damaged. If you read up on suggestions of many of the white wall paints, they recommend painting after installation with periodic touch ups if the tires are ridden. In the end I stripped off all the paint and went with the full white wall inserts.
I thought about that. I already mentioned that I didn't care all that much for the full white wall so there is a section around the bottom not painted. I'll also do it myself not on a machine.
