hey all, i have a leak at my tach and i think its the O-RING or possibly that whoever took it apart in the past didn't replace the two washers that go on either end of the drive shaft, my question is, can i remove the shaft that the tach cable plugs into without removing the whole assembly from the engine?
thanx
-hill
oil leak at the tachometer, can the tach be removed ?
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
'64 ca95 dream
'65 cb160
'66 cb77
so i circled the drive i want to remove from the base which is mounted to the top end via four bolts, its glued with a gasket so taking it off will just be a pain couse i'll have to make a new gasket. which is why i am hoping that the drive that held in by one bolt CAN be removed without taking off the housing and the four bolts holding the housing on..
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
'64 ca95 dream
'65 cb160
'66 cb77
