Gear Ratio
OldStan
Post by OldStan » Thu Jul 07, 2011 1:07 pm
By the way, if you ever do have your transmission opened up, I suggest you look into Xing 2nd and 3rd gears, which gives a more even spacing. Many prefer moving 2nd closer to 1st, and increasing the gap between 3rd and 4th gear ratios.
I believe Forest is talking about a CA. Swapping gear is not necessary, the stock gear ratios for 2nd and 3rd are different from the CB.
63 CA78
redblk63
Post by redblk63 » Thu Jul 07, 2011 1:36 pm
Thanks OldStan, I do not know beans about CAs. It makes sense they would have less "road racery" gearing.
OldStan
Post by OldStan » Thu Jul 07, 2011 1:46 pm
Check out this linkhttp://www.honda305.com/forums/viewtopi ... ansmission
It shows the power transmission path well.
63 CA78
