1967 CL77 Rear Fender Needed
I need a rear fender for my 1967 CL77. There is one on eBay but the seller isn't sure if it is from a 65, 66 or 67. Are the rear fenders different from these years?
Not to argue, but there is a mounting difference depending on the vintage. After 1033482 the fender and rear grab rail were rubber mounted. So the hole in the fender for the rear bolt is larger. Might even have affected the bracket welded to the fender, but never made an actual comparison, myself.
The chrome fender cut in at 1056274 so that would tell me that the chrome were all rubber mounted and the painted fenders came in both versions.
I also noticed an interim painted fender that was used from 1043098 to 1056273. It is in the rubber mounted range. Difference might be tail light holes (guessing at that) or possibly minor shape change.
regards,
Rob
regards,
Rob
Yes, you are correct! The 67s use a different tail light, the bolts, so a different bolt pattern. The grab rail is different as well betwwen the rubber and non-rubber mounted fenders. The give away for the 67 would be the tail light bracket holes in the fender! I have a decent chrome 67 fender, that could be de-chromed and painted. PM me if you're interested .
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
chrome fenders
I bought a 65 CL77 i think its a 65 the # is 100476D I have others tell me they think its a 65 because of the single front brake, my question is both fenders and chain guard is chrome, all the others i see on line are painted silver? any ideas? are they not OEM or was that an option in 65? I have never seen a chrome chain guard before. also does anyone know if the 65 chain guard shoild be solid or have the vents cutut on the sides? mine is solid.
any help would be great.
Thanks, Larry
Thanks, Larry
