Front shock and spring disassembly
ed1965dream
Post by ed1965dream » Thu Nov 03, 2011 10:43 pm
A couple more pictures.
Lower plate installed between shocks mounting tabs.
close up of the upper plates installed on spring
Jethro
Post by Jethro » Thu Nov 03, 2011 11:39 pm
Did you do anything with the seals or oil? I've been contemplating tearing into mine, they just don't work nearly as well as they used to.
ed1965dream
Post by ed1965dream » Fri Nov 04, 2011 6:56 am
Jethro wrote:Did you do anything with the seals or oil? I've been contemplating tearing into mine, they just don't work nearly as well as they used to.
No I didn't get into the seals. I had done a search but found nothing on replacement seals. There was one place that had shocks, but they were super expensive.
These shocks appeared to be in working order and weren't leaking so I left them as is. If there are replacement seals available I would dis-assemble and rebuild them. Have you found a source for the seals?
Jethro
Post by Jethro » Fri Nov 04, 2011 8:32 am
No but there was some talk on here not too long ago about it. I think in the section that covers suspension and some other things.
J
ed1965dream
Post by ed1965dream » Fri Nov 04, 2011 8:54 am
Jethro wrote:No but there was some talk on here not too long ago about it. I think in the section that covers suspension and some other things.
J
I've searched but found nothing specific. Some discussion about rears and front fork seals, but I couldn't find anything specific on the shock seals themselves.
Post by LOUD MOUSE » Fri Nov 04, 2011 9:09 am
I've worked on several of these shocks.
A bit tough to get the springs off. (but possible)
Really tough to get the shaft and seal out. (only time i do this is when I need to chrome the lower and adjuster)
These shocks dampen in one direction only. (rebound)
I've never found any replacement seals so I put the bad seal assy. aside for "MAYBE LATER". ...........lm
