Turning back speedometer miles
Kigsby
Post by Kigsby » Mon Dec 05, 2011 4:15 pm
I had to replace the speedo when I first bought the bike. The new odometer has twice as many miles on it as the original. Is there an easy way to turn the miles back to the correct miles that match my title? It's working just fine so I'm nervous about breaking it trying to fix the miles. Any easier options that opening it up? Is it that complicated? Any advise would be appreciated!
Post by G-Man » Tue Dec 06, 2011 8:02 am
Hi Kigsby
If you search on here for speedo repair you will find out how to take it apart. It's not the easiest of things to do but once you are inside, resetting the odometer is easy(ish).
Removing speedometer Bezel by graham.curtis, on Flickr
When you are inside you will see this clip which holds the odometer drum in.....
CB72 & CB77 Speedo Odometer Reset by graham.curtis, on Flickr
Might be easier just to wind it forwards with an electric drill.........
Good luck
Kigsby
Post by Kigsby » Tue Dec 06, 2011 9:18 am
Thanks G - I think I'm going to try to figure out if I can use a drill in reverse some how (the Ferris Bueller fix!) and if that doesn't work, I guess I'll have to open it up. While I'm in there I know I'll be tempted to start cleaning it up and that's when I'll break it! Thanks again for your help.
Post by davomoto » Tue Dec 06, 2011 10:15 am
Don't bother with the drill. It would take a month of 24/7 running to get it to zero.
Davo
Post by G-Man » Tue Dec 06, 2011 12:54 pm
Davo
Agreed - a bit of a stupid suggestion. You'd probably wear out the input bearings in the process, too...
Just worked it out - 60 days at 70mph to go once around the clock.......... :-)
Post by davomoto » Tue Dec 06, 2011 2:10 pm
Graham, don't ask me how I know better! :-)
Davo
