I guessed wrong on the grab rail/reat fender bolt and washer, according to the parts book they're supposed to be a regular 8x16 bolt and a spring washer, my bad.Hotshoe wrote:+ front fork boot clamps missing, should have chromed bolts and flat washers attaching the grab bar to the rear fender.
CHECK OUT THIS BIKE FOR CORRECTNESS "CL77 HONDA"
Not ta worry.
Look farther. ............lm
Hotshoe wrote:I guessed wrong on the grab rail/reat fender bolt and washer, according to the parts book they're supposed to be a regular 8x16 bolt and a spring washer, my bad.Hotshoe wrote:+ front fork boot clamps missing, should have chromed bolts and flat washers attaching the grab bar to the rear fender.
Fender bolts look like 6mm with a 10mm head - not the correct 5mm bolts. Washers missing.
Lock washer missing on headlight case setting bolt.
Seamed tank? For that serial number I would have expected a seamless tank.
There should be a fuel tank crossover line for this early of a model. There isn't one.
Do we need to keep looking or can we go to bed????
I'm not totally sure who has Trained Ya Eyes and Knowledge of these CL77 bikes but I'm impressed as to how many faults you identify.
I say this as a person I know purchased 2 CL77 bikes and they were similar to this.
What actual value would ya place for this as ya see it now and have identified any concerns?. ......lm
gopher wrote:Fender bolts look like 6mm with a 10mm head - not the correct 5mm bolts. Washers missing.
Seamed tank and no crossover are correct for a 67.
The braided wire is for the e-ignition stated in the auction.
Rear pegs are correct as well.
Perches and levers are wrong.
Black fork lock cover correct.
Seat should have silver piping
Top clamp and handlebar clamp should be bare, not painted.
You guys have caught many things that are not correct for sure!
Davo
Davo
Picky but clutch cable routed wrong, flat head screw in upper right of dyno cover should be a pan head.
Given matching numbers and clear title, if I was a buyer I think something between $3-4K would be fair.
As an owner, I hope it runs up!
