kick start assembly
rrrestorations
kick start assembly
Post by rrrestorations » Tue Apr 17, 2012 6:56 am
Need help on a basket case ca77 engine kickstart assembly.
all apart in pieces . I have the kicker shaft a spring and two washers.
No gears as I have seen in other posts. When I view a parts fiche diagram it does not show any gears, only a coil spring two washers and a c clip. My question is do I have missing parts or did they make different setups. The reason why i ask is because the parts diagram I downloaded only shows the coil spring ,washers and c clip no gears.
Please help.
Thanks,
Rob in Indiana
Re: kick start assembly
Post by LOUD MOUSE » Tue Apr 17, 2012 7:23 am
The CB72/77 uses gears as it is a Kick Forward assembly.
Yours is direct to the Kick Shaft. ..........lm
rrrestorations wrote:Need help on a basket case ca77 engine kickstart assembly.
Please help.
Thanks,
Rob in Indiana
rrrestorations
Post by rrrestorations » Tue Apr 17, 2012 7:35 am
Thanks for your help, LM
Rob in Indiana
Post by LOUD MOUSE » Tue Apr 17, 2012 7:44 am
Ya welcome.
BTW the spring mounts as if it was an "S" as ya look at it. ............lm
rrrestorations wrote:Thanks for your help, LM
Rob in Indiana
