63 honda 305, low and terrible voltage
bloodweiser
LOUD MOUSE wrote:Is it a full wave rectifier also?. ......lmquote]
I believe the answer to that is yes, LM. The rectifier takes the waves on the top and bottom of the zero point (crossing the X axis on a graph) and puts them all on the positive side like a row of army helmets. I believe (more ignorance about to show) that a half wave would just cancel out the negative portion of the waves and you would have just the positive portions conducted so it would be helmet, space, helmet, space...
regards,
Rob
Here you go. All you ever wanted to know about rectifiers but were afraid to ask.
http://en.wikipedia.org/wiki/Rectifier
regards,
Rob
regards,
Rob
Here it is....
http://www.radioshack.com/product/index ... Id=2062584
LM: I interpret your question as, "Is an SCR a full wave rectifier?"
The answer is no. It is a single diode (but controllable), so it can only serve as a half-wave rectifier. You could use 2 SCR's to make a full wave rectifier in the same way that you can use 2 of any diode type for full wave rectification.
You could use 4 SCR's in a 'bridge' configuration (that familiar diamond or square combination of 4 diodes) to achieve full wave rectification.
bloodweiser:
The terms 'full wave' and 'bridge' are not the same. Full wave means that both the negative and positive halves of the AC signal are being rectified. Bridge refers to the use of 4 diodes wired a certain way so as to achieve full wave rectification.
Wilf
bloodweiser:
Wilf
bloodweiser
A low and terrible update:
New battery.
Started perfectly and ran great for 20 minutes,
until it didn't.
No power at the side of the road, horn, lights, nothing.
Found my battery bubbling, warped and hissing,
and had it quickly disconnected.
Battery currently reads 11.5v
though I'm hesitant to try and use it again.
I'm hoping this is a simple dead original rectifier causing overcharging,
but am open to other interpretations.
I have yet to hook up a new, or different battery to see if what happens.
Any other possible damage from this incident?
New battery.
until it didn't.
'63 Dream
'68 CT90 (x2)
'76 RD400
'06 Xl1200R
'63 Dream
'68 CT90 (x2)
'76 RD400
'06 Xl1200R
