basement Dream
rzgkane
Post by rzgkane » Wed May 09, 2012 10:19 pm
Neutral light switch is behind the right crankcase cover and its wire is one of the 4 popping up through the hole in the crankcase (usually encased in black sheathing or heat shrink tubing). Green and yellow, I think. Ground that wire and if you get illumination at the neutral light you know you have a bad switch. If not, you have an issue between there and the bulb holder.
FatDog wrote:brewsky hanging in for the long haul! just have to comb and comb and wait for a busted up one that has good parts... i'm a craigslist wizard. (allofcraigs.com)
i got everything nearly sorted. except one minor issue:
the neutral switch will not light unless the bulb is grounded to the frame... but with the way the bulb is mounted (i did find the little rubber number) ... i do not see how it could ever contact the frame.
cheapo tip- a little tinfoil under the bulb in the black rubber neutral light mount made the neutral indicator lamp about twice as bright.
so close...
FD
