I have a CL77 with what I think is the wrong fuel supply valve.  The supply valve has two outlet nipples to supply fuel to each carb.  This is why I think the fuel valve is the wrong one, it also has an inlet nipple on the side of the valve that is blocked off by a small hose and screw in the hose.  I believe this side nipple on the fuel valve is for a cross feed line from the left side of the tank to the valve which is on the right side.
My question is, if the CL77 does not have a fuel outlet nipple to attach a cross feed fuel line running under the tank to the valve, how does the fuel get from the left side of the tank to the right side?  Just curious.
