Stops at 6000 rpm
Stops at 6000 rpm
I have a lovely early 305 that has just been recommissioned after a long storage. It starts and runs really well and carbs, points, timing, compression,etc., all look spot on but out on the road I can't get it to go much past 6000rpm. Any hints on what I can look at?
Hello and thanks. No I wouldn't know where Ed's recipe is, I've hardly ever used this board and I'm new to the bikes. Regarding the size and manufacturer of the needles and jetc I don't know and can't find out until I'm back home. Do you know what they should be?davomoto wrote:Did you set points and timing with Ed's tune up recipie? What jets, and needles, size and manufacturer are in the carbs? Altitude where you are?
Davo
