New member. No mechanical experience. Trying to improve that...
I have a '67 CA-77E. I bought it in non-running condition. The kickstart lever is stuck in the "Up" position. I've read several threads to try and remedy my problem. First I pulled the spark plugs out, and sprayed with PB penetrating catalyst. This did nothing.
Next I put the bike in neutral, it rolls fine. I then put the bike in gear, the back tire locks ups when I try to push it. I took off the Right side Crankcase cover. I was able to turn the motor with a socket wrench pretty easily. I believe this means the motor is not seized?
I assume my next step is to disassemble the right side of the motor? Take a peak inside and see what's happening? Or maybe I should lube up the grease fitting next to the kickstart? (I need to get a grease gun. Like I said, I have no mechanical experience)
Any and all feedback is greatly appreciated. Thank you for taking the time to read this "rookies" post.
Shane
Fayetteville, Arkansas
