Hi All,
Started the 1964 CB77 for the first time, used Bill Silvers book to set carb and timing and points. Bike idles fine, but when you crack the throttle it bogs right down and backfires though the carb. Any help is greatly appreciated.
Thanks, Carl
Bogs Down & Backfires Just Off Idle
Re: Bogs Down & Backfires Just Off Idle
What work have ya done to the carbs?. ....lm
carlluvscorinne wrote:Hi All,
Thanks, Carl
Carl, Have you checked your fuel valve and lines to the carbs. and just generally made sure your getting a good supply of fuel to carbs? If thats OK I'd check my float levels. Question; Is it just one side or both that backfire? I really think like L.M. suggests look at the carbs again. Good Luck! Steve Greer
