new cb77 owner. running/idle issues
Post by davomoto » Mon Oct 22, 2012 4:34 pm
I suggest you check the sync of the slides again. Sometimes the cable is a bit hung up somewhere.
Davo
mobilyte
Post by mobilyte » Mon Oct 22, 2012 8:21 pm
the throttle handle housing has a screw for adjusting friction on the throttle cable, that might be too tight.
conbs
Cable routing
Post by conbs » Mon Oct 22, 2012 11:07 pm
Take your air cleaners off and watch your slides as you pull the clutch lever in. I would take a look to make sure you do not have a cable routing/binding issue. You may still have some jetting issues that need to be sorted out, but there seems to be more going on than just that.
apophis
Post by apophis » Wed Oct 31, 2012 8:40 am
I got some new jets (138,140,142,145). I put in the 140's and it ran better from the start. I still cant bog the engine via the choke lever until its almost closed. my plugs look fine via color test though
