Timing chain replace
cleg
Post by cleg » Sun May 13, 2012 8:06 am
I just acquired another CB77 (blue 1966) on Craigslist that I could not do without, with that said the timing chain is noisy. I removed the tensioner and the center rib has chunks out of it, I believe from being too tight. I took the tensioner from my other 66 and installed it and adjusted tension. The chain is very noisy still so I am thinking that a new chain is in order. How difficult a task is it to replace? Anyone have a step by step? Thank you.
'66 CB77 '75 Rd125
Re: Timing chain replace
Post by LOUD MOUSE » Sun May 13, 2012 9:04 am
I would also be concerned about the other neoprene wheel in the middle of the engine.
Ya can use the old chain to loop in a new one. .........lm
cleg wrote:I just acquired another CB77 (blue 1966) on Craigslist that I could not do without, with that said the timing chain is noisy. I removed the tensioner and the center rib has chunks out of it, I believe from being too tight. I took the tensioner from my other 66 and installed it and adjusted tension. The chain is very noisy still so I am thinking that a new chain is in order. How difficult a task is it to replace? Anyone have a step by step? Thank you.
teazer
Post by teazer » Mon May 14, 2012 7:14 pm
LM is correct about those idler wheels. I have broken two and the result was a series of bent and broken parts in both cases.
hillhudson
Post by hillhudson » Mon May 14, 2012 10:00 pm
If you are not familiar with doing work on these engines such as cam chain replacement and such, I would first start by searching this forum for help, us the "search all terms" button, it will lead to a huge gallery of posts. Also, I'd buy bill silvers book, you can get it by contacting him through his website just google search "Bill Silver" "mr.honda".
@teazer,
How did those wheels brake on you ? I replaced mine with near mint looking ones from a lightly used spare engine, ( no cracks or chips) do you suggest periodically looking them over for wear?
-hill
P.s. lm, when will you put out the "LOUD MOUSE" Honda 305 manual ??? :)
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
cleg
Post by cleg » Sun Oct 28, 2012 8:35 am
Is the part # for the lower cam chain wheel 14611-250-310? As far as the the tensioner, are there early and late versions?
It's been a while since the post, but between work an other issues I may someday get this done.
'66 CB77 '75 Rd125
Post by LOUD MOUSE » Sun Oct 28, 2012 8:45 am
That is the guide in the center of the engine.
The tensioner is at the rear of the cylinder and came in 2 sizes.
The engine number will give the correct one needed in the parts book. ................lm
cleg wrote:Is the part # for the lower cam chain wheel 14611-250-310? As far as the the tensioner, are there early and late versions?
