What's the consensus from the forum on dirt bike foam vs. filter paper? I'm going to replace my air filter as opposed to paying $35-60 for a replica.
I see a few people have done this. I'm curious about how long the "glue" held up? Which glue would be best? Also, which medium is easier to clean, foam or paper?
[EDIT] How much would I have to tweak my carb to offset the new mixture when using a foam instead of filter paper?
Thanks,
Dave
Air Filter Refurbish
davesdreamin
davesdreamin
rad!
Thanks so much for the advice guys.
previous owner of my dream replaced the paper with foam using hot glue. When I took it off the glue had not completely sealed around the foam or had come loose.
Foam is not that hard to clean when it can be remove from the frame, but I can't see how it can be cleaned properly when permanently attached. I went back to paper.
63 CA78
