What's the trick for the rear axle?!?
piecutter
Post by piecutter » Sun Jun 03, 2007 5:49 pm
Yes, "C" is a flanged spacer. Sounds like it's rusted to your axle. You might try grabbing it with a pair of vise grips and rotating it against the axle to try and free it up. You are probably going to need a new axle at the very least, so cutting is likely a good option as well.
piecutter
Post by piecutter » Sun Jun 03, 2007 5:59 pm
And, yes, according to the parts diagram the axle is installed from the right side, but if you look at the photos in the service manual it is seen to be installed from the left side. I don't think there is a clear reason for it to be installed from either side and not the other as long as the spacers are placed correctly, which, from your pictures, seems to be true.
Re: Two weeks later...
Post by LOUD MOUSE » Sun Jun 03, 2007 7:16 pm
YES!!!!!!!!!!!!!!
It's installed from the wrong side.
Once again "THAT SAID" use vise grip pliers on the SPACER then turn/twist that axle.
The pic shows that the axle will come through the wheel so what's the big deal to realize that the axle is rusted/seized to the spacer??????????????. ..........lm
mopower wrote:
LOUD MOUSE wrote:The axle is installed from the wrong side. That said I recommend you put some/more penetrating fluid on the spacer and adjuster. Grip the spacer with vise grips and put a rod or something in the hole in the axle and make these parts move/twist/turn. Add what amount more of the liquid and continue moving the spacer on the axle and as you do apply out pull on the axle as you twist the axle. ........................lm
Wrong side?!? How is that even possible? It looks right according to my manual. So you're saying that thing that arrow C is pointing to should twist separately from the axle or together? Haven't tried that yet.
Thanks everyone for the tips.
mopower
Post by mopower » Mon Jun 04, 2007 9:37 am
LOUD MOUSE wrote:YES!!!!!!!!!!!!!!
It's not a big deal and I appreciate all the advice and tips. I've just never taken one of these apart before so I have no idea what it actually looks like or what to expect. I don't have the parts manual, only the service manual. And the idea that you could actually install something as critical as an axle in backwards with no noticeable effect is so completely foreign to me that I didn't even think it was possible. Again, I'm not doubting you or your experience, I'm just a little freaked out that something could be completely ass-backwards and assemble and operate like normal.
305racer
Post by 305racer » Mon Jun 04, 2007 4:07 pm
How is that?
piecutter
Post by piecutter » Mon Jun 04, 2007 9:00 pm
Look in the gallery section here. You'll notice that half the bikes there look like they have the axles in from the right. Most people go right to the parts diagram for assembly tips and, of course, install it that way.
305racer
Post by 305racer » Mon Jun 04, 2007 9:27 pm
piecutter wrote:Look in the gallery section here. You'll notice that half the bikes there look like they have the axles in from the right. Most people go right to the parts diagram for assembly tips and, of course, install it that way.
Sorry I meant to say why does it matter which way it goes in?
