oil seals
raygray11
oil seals
Post by raygray11 » Sat Jul 06, 2013 6:23 am
Hi new member from Essex UK first post
Is it possible to change oil seals on offside of engine without spliting cases.
\have oil leak on newly aquired bike otherwise running fine.
Cb 72 1965
Ray
Post by G-Man » Sat Jul 06, 2013 12:32 pm
Should be possible. Getting the old ones out will be quite tricky. Which one is leaking?
raygray11
Post by raygray11 » Sat Jul 06, 2013 2:27 pm
Hi thanks not sure which one is leaking yet have yet to remove cover.
Oil leaking onto chain and spraying rear tyre also a little wet near front of starter cover
Ray
Re: oil seals
Post by LOUD MOUSE » Sat Jul 06, 2013 5:40 pm
You may find the seal at the clutch rod is the problem.
No problem removing or installing a new one.
If you find the leak is with a seal in the cases I recommend you use a knife and cut the sharp edge of the case at that location.
Do Not put any sealer as Permatex as the seal will pop out as you ride. ......lm
raygray11 wrote:Hi new member from Essex UK first post
Cb 72 1965
Ray
raygray11
Post by raygray11 » Sun Jul 07, 2013 2:02 am
Many thanks to all for replys.
I had considered looking at the breather also in case that was not helping.
I have had a Vincent for 40 years so am still finding my way round the Honda.
very different sort of animal.
Ray
Spargett
Post by Spargett » Sun Oct 06, 2013 4:16 am
Any luck on the issue ray?
Congrats on the Honda, sounds like you're racking up the cool bikes.
