Anti-Gravity Battery
JSharpPhoto
Post by JSharpPhoto » Fri Sep 13, 2013 10:36 pm
I'm looking to replace my battery with something a bit smaller. I've been advised to look at the anti-gravity batteries. They're very small, and don't get damaged if they're completely drained, unlike other batteries.
There's the 4 cell, and the 8 cell.
The 4 cell says "Capable of every day use in bikes up to 250cc"
The 8 cell says "Capable of every day use in bikes up to 550cc"
My bike is a kickstart only 1967 CB77. Do you guys think the 4 cell would handle my super hawk? or do I need to go up to the 8 cell to be safe?
http://antigravitybatteries.com/small-case-batteries/
JSharpPhoto
Post by JSharpPhoto » Fri Sep 13, 2013 11:39 pm
Or should I just go with an AGM battery? I can lay that on its side, right?
http://www.impactbattery.com/mb9u-motob ... yb7-a.html
brewsky
Post by brewsky » Sat Sep 14, 2013 6:41 am
no experience, but a quote from their website......
" (Please note if you use older classic bikes from mid 1980s and earlier you should update the charging sytems to a modern voltage regulator)"
I have read that they don't like to be overcharged, and they contain a flammable, PRESSURIZED electrolyte
One of the electrical guru's will hopefully chime in...
Superchicken
Post by Superchicken » Sat Sep 14, 2013 9:25 am
JS, the AGM is very close to the stock battery, but has more cranking amps and no acid overflow tube. I have not run one on my super hawk, tho the one on my yama vision lasted 9 years! Fully charged they are 12.8 volts, it only needs to be charged if it gets down to 12.6 volts
JSharpPhoto
Post by JSharpPhoto » Sat Sep 14, 2013 7:03 pm
Can someone confirm that a AGM can be mounted laying on its side?
Superchicken
Post by Superchicken » Sat Sep 14, 2013 10:51 pm
yes they can be any position
JSharpPhoto
Post by JSharpPhoto » Sat Sep 14, 2013 11:54 pm
Well that solves that. I can mount it laying down inside my seat hump.
