Grease for CB77 Starter Clutch
mcconnellfrance
Post by mcconnellfrance » Sat Sep 21, 2013 3:45 pm
I am refurbishing the starter clutch of my CB77. The Manual recommends using a Honda special silicone grease on the rollers and springs in the clutch. Any one know of an alternative grease which will working in this application?
Regards,
Gordon McConnell
Goodysnap
Re: Grease for CB77 Starter Clutch
Post by Goodysnap » Sat Sep 21, 2013 5:13 pm
mcconnellfrance wrote:I am refurbishing the starter clutch of my CB77. The Manual recommends using a Honda special silicone grease on the rollers and springs in the clutch. Any one know of an alternative grease which will working in this application?
Regards,
Gordon McConnell
Here is some related discussion-
http://www.honda305.com/forums/starter- ... ght=clutch
I swear I remember somebody mentioning no lube in this area. At least on the rollers anyhow. Lube in the starter clutch area will only help the rollers slip where they need to grab.
Maybe someone else can confirm this? Maybe the manual is referring to the starter gears that need lube?
At any rate- a synthetic brake caliper grease or dielectric grease would work as a substitute as both are silicone based. 3M offers a silicone paste as well.
HTH
64' CB77
65' CB160
rrietman
Post by rrietman » Sat Sep 21, 2013 9:37 pm
assemble dry. no grease! make REALLY sure the FH screws are secure, I.E. staked in place. very common failure to have them back out and cause a mess.
Randy
mcconnellfrance
Post by mcconnellfrance » Sun Sep 22, 2013 6:48 am
Thanks guys for the advice. I see on one of the past posts that Molykote or graphite grease was used by someone. However, I can understand the logic for no grease at all. Will be stripping it next weekend so will see what I find inside.
Regards,
Gordon
