My Dream Begins (Restoration Project)
Those wheel rims make me sad.
I'd feel better if you let me donate my old rims to your project. I just replaced ours with new stainless steel rims from the UK. I was thinking of putting the old ones up for auction, but you can have them for free. They're not show quality, but they are true and fairly clean looking, compared to your existing ones. I also have the spokes and nipples that went with them if you'd like those too.
If you PM me your actual email, I'll send some high resolution images to you so you can see what they look like.
Had: '75 CB550 K, '79 CT90
Awesome Bob! Thank you. I appreciate any help I can get. Did you end up replacing your wiring harness? The deeper I get in the more wiring issues I find. I'm not asking you for your old one, I just remember reading in your thread that you were considering ordering a new one. Was wondering how that worked out for you, in case I need to do the same.Bob750 wrote:Those wheel rims make me sad.
Thanks again Bob. I'll send you my info.
Joey
I did not get a new one. I've cleaned up my existing one and will use that. It was working fine before I took everything apart. I'll revisit getting a new one if I ever start having bad electrical issues...Bradha562 wrote:Awesome Bob! Thank you. I appreciate any help I can get. Did you end up replacing your wiring harness? The deeper I get in the more wiring issues I find. I'm not asking you for your old one, I just remember reading in your thread that you were considering ordering a new one. Was wondering how that worked out for you, in case I need to do the same.Bob750 wrote:Those wheel rims make me sad.
Joey
This weekends so called progress...
The 26 year old oil has turned to sludge.
The gunk that came out of the clutch cover.
Pulled the exhaust and chain cover. Received new points, condenser and plugs. Next up is dropping the motor. How much does the motor weigh?
Thanks for looking, your thoughts and suggestions are always appreciated.
And so it continues...
Petcock off:
Gotta love a Pinesol bath:
Trying to source some fuel lines. I read a post here where a member was able to find some lines at his local Honda store, I wasn't so lucky. Any suggestions for lines?
