4th gear not there
Post by G-Man » Wed Jul 23, 2014 11:39 am
Woody
You're in a much better position to find the answer to that question than I am......
I rarely perform miracles, let alone at 3000 miles away.... :-)
You're going to have to look inside my friend.
woodrow
Post by woodrow » Wed Sep 24, 2014 10:32 pm
I finally got the time to look in to my problem and discovered that I have a 13 tooth front drive sprocket which had me revved up so high going down the road that I thought I wasn't getting out of third gear. Can anyone tell me what the correct size forward drive sprocket I should be running on this 1966 305 scrambler? I know it has the shallow splines. Also what size sprocket belongs on the back? Anyone know where to locate these sprockets? I have read that the shallow forward sprockets are hard to find. Thanks Woody
Post by G-Man » Thu Sep 25, 2014 2:24 am
Front 15T
Rear 40T
Ohio cycle has the front sprocket.
http://www.ohiocycle.com/catalog2.html
Post by LOUD MOUSE » Thu Sep 25, 2014 6:36 am
A 15 tooth front and as you have a CL77 a 37 rear.
I may have the front. ............lm
woodrow wrote:I finally got the time to look in to my problem and discovered that I have a 13 tooth front drive sprocket which had me revved up so high going down the road that I thought I wasn't getting out of third gear. Can anyone tell me what the correct size forward drive sprocket I should be running on this 1966 305 scrambler? I know it has the shallow splines. Also what size sprocket belongs on the back? Anyone know where to locate these sprockets? I have read that the shallow forward sprockets are hard to find. Thanks Woody
Post by G-Man » Thu Sep 25, 2014 10:54 am
woodrow
Post by woodrow » Thu Sep 25, 2014 6:58 pm
Thanks G man and Loud Mouse for the info, I think we got this problem solved
Post by G-Man » Fri Sep 26, 2014 2:15 am
Woody
Depending on what sprockets you can find to purchase, 17/40 will give you a slightly higher gearing than 15/37. 16/40 will get you near standard gearing with non standard sprockets.
17 / 40 = 0.425
16 / 40 = 0.400
15 / 37 = 0.405
