                    help with restoration
Yes its good int it.
Not only was the engine seized, the rear chain is seized, the rear brake was seized on and the rear mudguard was sitting on top of the tyre ( tyre, I use the term loosely old rubber band around the rear rim ). No wonder it wouldn't move.
What have I bought here. I will have to hide it from the misses.
D
D
What you see is what I have got. This is how it came off the transport that delivered it.
Im not blessed with patience it comes with working as a field service engineer for 45 years. When your out in the field on a breakdown and on you own you learn to do what you have to do to fix the machine. A piston that's seized to that extent I wouldn't want to use again anyway so get it out and move on. Looks like I need to make a puller for the rotor. I am not too bothered about originality if so if there is something that's not available or too expensive I will make the part or use something else. At least it will be running and back on the road and not lying in a barn rusting away.
I bought a swinging arm on ebay it came today nice one too. The old was rotted away. The petrol tap disintegrated when I tried to take it off today and I don't know where its been but the petrol tank was half full of what looks like sand or dirt and the tank has more holes than a lace curtain. What about this primary chain, over engineered or what looks like it should be on a forklift.Good this int it.
Took the sump off to clean the swarf out after drilling the piston. Bought a 16mm fine bolt to draw the rotor off and found the sprag clutch for the starter was all rusted up. Anyway its sorted now.
Regarding the drive gear for filter. It isn't fixed to the crankshaft its just clamped between the engine sprocket and a sprung washer held on with a tab washer. I take it that its not designed to be tightened up tight so it can slip if the filter becomes blocked. Is this correct.
if its not broke don't fix it.
Aermacchi ss350
Gilera 124
James SC1 Scooter
Honda CA77
						Aermacchi ss350
Gilera 124
James SC1 Scooter
Honda CA77
No.
Tighten the nut as hard as you can.
There is no reason the gear should/would slip. ........lm
pieeater wrote:Took the sump off to clean the swarf out after drilling the piston. Bought a 16mm fine bolt to draw the rotor off and found the sprag clutch for the starter was all rusted up. Anyway its sorted now.
