eamartin
Post
by eamartin » Sat Nov 08, 2014 4:01 pm
I have a CA78 which has not been ridden or even started for about 10 years. Each month it would be kicked over a few times but that's it. Tires would no longer hold air so new tubes have been installed. Carb has been cleaned and re-installed. Petcock is currently disassembled and awaiting parts. A new battery sits on the shelf. What other issues ought to be addressed before attempting to start this machine?
mike1969
Post
by mike1969 » Sat Nov 08, 2014 4:33 pm
How is the inside of the tank? Rusty?
Hamamatsu Nippon
Post
by Hamamatsu Nippon » Sat Nov 08, 2014 6:29 pm
Dump the oil and clean the centrifugal filter. Take a close look at your old oil. Check for gasoline contamination and metal fillings.
1967 CA78
1965 CM90
Soichiro Honda
eamartin
Post
by eamartin » Sat Nov 08, 2014 6:48 pm
mike1969 wrote:How is the inside of the tank? Rusty?
Fuel tank is clean.
eamartin
Post
by eamartin » Sat Nov 08, 2014 6:49 pm
Hamamatsu Nippon wrote:Dump the oil and clean the centrifugal filter. Take a close look at your old oil. Check for gasoline contamination and metal fillings.
Okay. Sounds easy enough.
OldStan
Post
by OldStan » Sat Nov 08, 2014 6:57 pm
Tires over 10 years old (surely they weren't new then) should be replaced along with the tubes.
Do you know why it was parked? Might give you an idea of what else should be checked.
63 CA78
eamartin
Post
by eamartin » Sat Nov 08, 2014 8:16 pm
OldStan wrote:Tires over 10 years old (surely they weren't new then) should be replaced along with the tubes.
I don't intend to ride this bike. I'm prepping to sell and these are the original narrow whitewalls which I'd like to keep mounted on the bike.
