sarals
Post
by sarals » Fri Nov 21, 2014 8:47 pm
How did you make out with the brake cable?
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
jugger18
Post
by jugger18 » Sat Nov 22, 2014 2:51 pm
It is stubbornly still attached along with the top engine mount bolt
sarals
Post
by sarals » Sat Nov 22, 2014 5:15 pm
Penetrating oil? :)
1989 NT650 Hawk GT
jugger18
Post
by jugger18 » Sat Nov 22, 2014 5:20 pm
Mounting bolt is soaking in PB. What is the best way to get the break linkage off the hub splines?
Post
by G-Man » Sun Nov 23, 2014 4:01 am
Just slacken the pinch bolts and lever the arms off with a couple of screwdrivers.
Waveblaster
Post
by Waveblaster » Sun Nov 23, 2014 8:49 am
A small gas torch is helpful for stubborn nuts and bolts, thinks like engine mounts I found react favourably to a bit of heat. Just be careful of rubber and wiring etc when heating things
jugger18
Post
by jugger18 » Sun Nov 23, 2014 5:36 pm
Brake cable is off. Engine bolt has gone through 3 rounds of pb blaster, and a propane torch. I have the nut off but the bolt is frozen. Air impact wrench wont even budge it. Guess I will add more pb blaster and let it soak a few more days. Tonight I will attempt to remove the old tires as I bought the set Kevin offered and the should be here tomorrow :)
