connecting rod sleeves?
Farm Shop
Post by Farm Shop » Thu Dec 18, 2014 12:51 pm
As long as I find a crank from a scrambler they are all the same from 65 to 68 for the 305 correct?
Post by LOUD MOUSE » Thu Dec 18, 2014 2:31 pm
The CL77 cranks are the same. ........lm
Farm Shop wrote:As long as I find a crank from a scrambler they are all the same from 65 to 68 for the 305 correct?
Farm Shop
Post by Farm Shop » Thu Dec 18, 2014 3:30 pm
Thank you much Loud Mouse!
teazer
Post by teazer » Mon Jan 05, 2015 3:39 pm
I have had CB77 con rods machine and sleeved, but the crank was split to do it. It had to come apart to clean out the hard crud in the oil slinger grooves and to be lightened.
I had a different shop machine a smaller Cb160 con rod - on the crank. They needed to support the crank and just clamped teh rod down fairly hard to stop it from moving. The same approach would work with a Bridgeport mill for a CL/CB 305 crank.
Superchicken
Post by Superchicken » Wed Jan 07, 2015 9:48 am
Cranks on CB's have an oil hole to lube the starter clutch, CL's have no hole.
R100
Post by R100 » Wed Jan 07, 2015 10:58 am
Superchicken wrote:Cranks on CB's have an oil hole to lube the starter clutch, CL's have no hole.
Is it still possible to run a CB with the starter motor removed, even with that oil hole in the crankshaft?
Post by LOUD MOUSE » Wed Jan 07, 2015 11:03 am
Fill the hole in the end shaft or leave the starter sprocket with a good seal on the shaft. .........lm
