Steverino
Post
by Steverino » Tue May 05, 2015 11:13 am
Thank You G Man
I dug out one of the old bushes and I was surprised that the difference is not nearly as great as I thought. I have removed the powder coating from the mating surface on the frame but there is still a long way to go. The swingarm does not appear to be bent.
CAM01967 by
stevesteverinomeister, on Flickr
malcolmgb
Post
by malcolmgb » Tue May 05, 2015 12:26 pm
Did you also remove the powder coating from the swingarm, that would reduce the distance between the bushes.
Something else to look at is if you had to knock the swingarm pivot bolt out you can move the frame bushes, they are just pressed in.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post
by G-Man » Tue May 05, 2015 12:29 pm
Steve
You might be able to use a sander to remove the bulk of that, but I would revert to hand tools to remove the last 20 thou or so each side.
On a positive note, you will have a really superb, close fitting swing arm when you have finished.... :-)
Steverino wrote:Thank You G Man
CAM01967 by
Post
by G-Man » Tue May 05, 2015 12:31 pm
Malcolm
Good point.
malcolmgb wrote:Did you also remove the powder coating from the swingarm, that would reduce the distance between the bushes.
Steverino
Post
by Steverino » Tue May 05, 2015 8:34 pm
Thank You Malcolm and G Man
I have bare metal contact behind the flange and between the flange faces. I am working on moving the frame flanges inward at this point. I thought they were welded in place. They sure look like they are welded.
Post
by G-Man » Wed May 06, 2015 3:20 am
Steve
Outside dimension for the frame bushes measures 162mm on a frame that I have access to.
48lesco
Post
by 48lesco » Wed May 06, 2015 11:22 am
Those flanges are welded on all the CB77's I've seen. Once you get the inside bushings to fit on the frame flanges, also be sure that the inner steel bushings are slightly proud of the brass on the outside. The pivot bolt needs to tighten down on those inner steel bushings and not the outer brass or phenolic ones. Otherwise the swingarm will be grounded to the frame which will lead to disappointment.
