Wow, quite the story LM! Will certainly reference this info while at the machine shop.
I spoke to the owner of the shop today and he has been in business for 30+ yrs so my hopes are that he has some knowledge with these 305's (which im sure he will) will keep you updated on the progress! Thanks again!
First post and soon-to-be owner of '65 CL77
I share my experiences with others because I've been there in so many ways and now I find others headed into some of the same things I've experienced. (not all good or bad)
Then it's time to let them make up their own mind. ..................lm
rideordie wrote:Wow, quite the story LM! Will certainly reference this info while at the machine shop.
Much appreciated LM, personal experience is always good advice!
While we are on the topic...below are the pistons I ordered (61.00mm), would you recommend that I go 2 TH clearance with these as well or should different calculations be made?
Also, what does TH stand for? lol
- pistons.PNG (120.55 KiB) Viewed 2483 times
In this case I suggest you ask Tim that question as he had WISCO build them.
TH is for THOUSAND. ......................lm
rideordie wrote:Much appreciated LM, personal experience is always good advice!
