Post
by Seadog » Wed Jul 29, 2015 3:46 pm
Thanks, G. I can't get it here, but knowing what it's designed to do - clean carbs and machine parts - helps. I settled on this stuff, which is billed as doing essentially the same thing:
http://www.ebay.com/itm/221596612155?_t ... EBIDX%3AIT
This afternoon, I've been fiddling with the bridge plate, trying to understand how the damper ring works when it's located under the stem nut, but on top of the bridge plate. It just spins freely. Can you explain it's function? Is there an order to tightening the stem nut and the two bridge bolts? What came first, the chicken or the egg….
G-Man wrote:Seadog
Great work with lots of patience. These are the guys I get my ultrasonic cleaning stuff from. I realise that it's not much help to my N-A friends but it might give you some clues. I use their carb and machine part clening solution. I get it 1 gallon at a time now. It's expensive but does the job.
http://www.allendale-ultrasonics.co.uk
Post
by G-Man » Wed Jul 29, 2015 4:02 pm
I took several pictures when I pulled my C72 apart. Too many to post here but scroll down the Flickr page and this might help.
Mine is a pressed-bar bike so the top plate will be different.
https://www.flickr.com/photos/63154743@ ... 3926089106
Post
by Seadog » Wed Jul 29, 2015 4:46 pm
What an idiot I am. The damper ring must merely provide the vertical core for the stacked steering damper washers. It doesn't need to be tight, just keep those washers and parts together in a neat stack.
Thanks for your help, the photos were great.
Post
by G-Man » Thu Jul 30, 2015 12:59 am
You're welcome.... :-)
Seadog wrote:What an idiot I am. The damper ring must merely provide the vertical core for the stacked steering damper washers. It doesn't need to be tight, just keep those washers and parts together in a neat stack.
Post
by Seadog » Thu Jul 30, 2015 3:27 pm
Life's little trials and tribulations.
When I was cleaning the floor in my shop last night, I found an end cap to something. It wasn't until later that it dawned upon me what it was - one of the 4 caps covering the front suspension arm bushings. It must have fallen off when I was mounting the front shocks in the fork yesterday. I just never noticed it was gone. So, off the front fork came and the suspension after.
It was a good thing too. Shame on me for not checking those bushings, collars and seals before assembly. They really need replacing. One sleeve was pretty rusted and the other was actually worn in such a way that it was fitting into the groove in the center of the bushing.
Fortunately, Ohio Cycle has the parts and I ordered them today with a bunch of other things. Now I'll have to wait for awhile to pick back up on assembly, but there's plenty to do in the mean time. Besides, I'll need time to figure out how to remove and replace those fiber bushings….
You just have to chuckle.
- The rusty collar
- IMG_0751.JPG (141.37 KiB) Viewed 1452 times
- The worn collar
- IMG_0757.JPG (85.88 KiB) Viewed 1452 times
- The stray
- IMG_0750.JPG (143.98 KiB) Viewed 1452 times
Post
by Seadog » Thu Jul 30, 2015 4:30 pm
Necessity is the mother of invention, but now that I have them out (undamaged), how do I get the new ones back in? I'll have to think on it.
- Done
- IMG_0762.JPG (89.11 KiB) Viewed 1438 times
- Out
- IMG_0760.JPG (108.62 KiB) Viewed 1438 times
- Started
- IMG_0759.JPG (133.4 KiB) Viewed 1438 times
Post
by G-Man » Fri Jul 31, 2015 12:32 am
Nice solution. They are quite tricky to remove in one piece and I don't think that those fibre bushes do any favours to the handling. I am going to make some bronze bushes for mine and I did enjoy making this little tool to get them out intact.....
The important thing is to support the bush as it goes in or out, otherwise it is going to collapse.
Seadog wrote:Necessity is the mother of invention, but now that I have them out (undamaged), how do I get the new ones back in? I'll have to think on it.
