It Lives!
It Lives!
I was able to get the black Dream going today, a friend of mine helped me with the carb and it runs! I was able to ride it around the block, then came back to adjust a couple of things. The electric starter now engages when you turn the key on and keeps going after the bike starts. That seems like it should be a simple fix but I'm not sure where to start. The starter button doesn't work (feels like nothing there) so maybe I will disconnect at starter relay and see if that leaves it rideable for now. Ran good so looking forward to real test drive. Thanks for the help.
- Contact:
It sounds sort of like the starter button is stuck closed. It's not a complex circuit so it should be easy to find the issue. I would begin by disassembling the starter switch housing. Just a button, a spring and some contacts.
Oilleak
http://www.oilleak.net
Those who give up liberty for the sake of security deserve neither liberty nor security.
--- Ben Franklin
--- Ben Franklin
