Well put-together articles on controlling valves and how things have developed over the years. Presented as a pursuit of higher revs but relevant to make an 'ordinary' engine run with lower stress, too.....
http://www.cycleworld.com/2013/12/24/va ... n-cameron/
Engine Technology
Engine Technology
honda brian
OldScrambler
Very interesting. I learned a thing or two. I thought the inner valve springs were for added pressure to keep the valves from floating. Pretty obvious I have no formal training. Hey Old Scrambler here is my CB750. I ride it whenever weather permits. It's never been apart and has 8000 miles on it. The more I ride it the better it runs. I am quite often approached by guys my age and older that want a closer look.
cb750right by Steve Steverinomeister, on Flickr
cb750right by Steve Steverinomeister, on Flickr-
OldScrambler
Nice K6...........their only original ONCE! I ride my original K3 somewhat sparingly, but it did make a few recent miles in Idaho, Utah, Nevada and New Mexico.
I have same ID on sohc4.net...................lots of info and interest on all things SOHC-4
My CB750 build is on the high-performance page under Classic Bonneville Racer
I am building a CL77 motor to use in a custom dual-sport build. It will have the 3mm-oversize pistons and thinking about experimenting with modern valve components...........although mildly porting the intakes on the head may be all I need.
Steve
The inner springs don't do much, tension-wise as they are much smaller. They do however act as a friction surge damper for the otters at high revs. Notice how they are wound in the opposite direction so they don't snag the outers.
Steverino wrote:Very interesting. I learned a thing or two. I thought the inner valve springs were for added pressure to keep the valves from floating. Pretty obvious I have no formal training. Hey Old Scrambler here is my CB750. I ride it whenever weather permits. It's never been apart and has 8000 miles on it. The more I ride it the better it runs. I am quite often approached by guys my age and older that want a closer look.
