gearhead3275
Post
by gearhead3275 » Sun Oct 11, 2015 1:55 pm
Still nothing...
mike1969
Post
by mike1969 » Mon Oct 12, 2015 6:41 am
Your clutch plates may be stuck together. You'll have to remove the left side cover and remove the clutch plates and clean them.
gearhead3275
Post
by gearhead3275 » Tue Oct 13, 2015 6:03 am
I'll get that done and get back to you...Thanks for the help.
mike1969
Post
by mike1969 » Tue Oct 13, 2015 7:29 pm
Good luck. You can pull the clutch lever to see if the plates are separating without putting the side cover on.
gearhead3275
Post
by gearhead3275 » Wed Oct 14, 2015 6:32 am
Ok, Ill open it up this weekend and let you know..
gearhead3275
Post
by gearhead3275 » Thu Oct 15, 2015 4:28 pm
Tried to open it up tonight but couldn't get any of the screws out of the clutch side housing. Anyone have tips on how to do this without screwing up the heads worse than they are now. Sprayed them down with lubricant and going to let them soak over night. Not one budged.
R100
Post
by R100 » Thu Oct 15, 2015 4:56 pm
gearhead3275 wrote:Tried to open it up tonight but couldn't get any of the screws out of the clutch side housing. Anyone have tips on how to do this without screwing up the heads worse than they are now. Sprayed them down with lubricant and going to let them soak over night. Not one budged.
Impact driver.
