Speedo needle broke!!!
ericmanuel
Post by ericmanuel » Sat Nov 07, 2015 1:39 pm
Do know how it happened but the speedo needle broke off. Any ideas on if this can be repaired or just replaced.
~Eric
Post by G-Man » Sat Nov 07, 2015 2:19 pm
Eric
I cannot see you picture. Speedos can be opened up for replacing the needle or any other parts. Was it jumping around befor it broke?
ericmanuel
Post by ericmanuel » Sat Nov 07, 2015 2:28 pm
It was working perfectly. I was running an errand and came home. Went to go back out and noticed it was broken.
Is there a teardown instruction somewhere?
Thanks in advance for your here.
~Eric
Post by G-Man » Sat Nov 07, 2015 2:41 pm
Eric
There have been a number of posts here on strip down and repair. Alternatively there is a company in Sandiego that repair Honda speedos.
http://www.foreignspeedoinc.com/
The hardest part is removing the bezel which must be carefully prised up using successively larger screwdrivers. After that it is pretty straightforward. What bike do you have?
ericmanuel
Post by ericmanuel » Sat Nov 07, 2015 3:08 pm
It's a '64 Ca77
ImageIMG_0003 by Eric Manuel, on Flickr
Re: Speedo needle broke!!!
Post by LOUD MOUSE » Sat Nov 07, 2015 4:22 pm
Usually requires a replacement.. ...........lm
ericmanuel wrote:Do know how it happened but the speedo needle broke off. Any ideas on if this can be repaired or just replaced.
~Eric
hondadreamca77
Broke Speedo
Post by hondadreamca77 » Tue Nov 24, 2015 12:05 pm
My CA77 speedo needle did the same thing. It was caused by the speedo cable nut coming loose where it attaches to bottom of speedo.
I took it all apart, replaced the needle with a needle off an old pressure gauge and also lubed the odometer gears while I had it apart.
Doesn't look factory but will do for now till I find a OEM part.
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
