Boring costs?
jensey
Post by jensey » Thu Jan 28, 2016 2:30 pm
You assume that the quality of boring is always the same and not depending on price ?
jugger18
Post by jugger18 » Thu Jan 28, 2016 2:31 pm
In most cases I have found that assuming higher price = higher quality has not been true. I will take personal recommendations into higher consideration
jugger18
Post by jugger18 » Thu Jan 28, 2016 2:32 pm
That being said. Is there any specific questions I should be asking to assure I am getting a quality job?
jensey
Post by jensey » Thu Jan 28, 2016 2:33 pm
I don't say that a higher price is a better bore, I say you may have your priority's wrong.
BORE
Post by LOUD MOUSE » Thu Jan 28, 2016 8:01 pm
I've used this shop since 2000 and always a good job.
I know that the chances that a real machine shop will cost a bit more as there is a shop of professionals doing the work. ....................lm
jensey wrote:I don't say that a higher price is a better bore, I say you may have your priority's wrong.
OldScrambler
Post by OldScrambler » Fri Jan 29, 2016 2:04 pm
Before you send your barrels.............do you have the pistons and rings in-hand? If so, send along with the barrels..........a PROFESSIONAL SHOP will bore each hole to provide the proper skirt-clearance..........and will usually ask if the application is for everyday-use or some sort of high-performance application. A 0.50 or 0.75mm over-sized bore will usually cure typical scores and pits in the liners.
I use and always recommend MELLENIUM TECHNOLOGIES.........in Plymouth, WI.........look them up with GOOGLE...........Last year I had several bores completed at a little less than $50 per hole..........of course I don't have expensive shipping because they are about 6-miles from my door. Your price may vary...........?
Post by LOUD MOUSE » Fri Jan 29, 2016 2:25 pm
I paid that amount when I lived in Fort Worth but that was back about 1995.
Ah the good old days......................lm
OldScrambler wrote:Before you send your barrels.............do you have the pistons and rings in-hand? If so, send along with the barrels..........a PROFESSIONAL SHOP will bore each hole to provide the proper skirt-clearance..........and will usually ask if the application is for everyday-use or some sort of high-performance application. A 0.50 or 0.75mm over-sized bore will usually cure typical scores and pits in the liners.
