Flywheel Puller Question
Thank You Everyone. I'm not going to waste any more time waiting for my second puller to show up. I'll just go get a 16mm 1.5 bolt. This little problem has been holding me up for a couple weeks. Sadly, I've had to fill the time by riding my new CB1100.
KIMG0325 by Steve Steverinomeister, on Flickr
Puller Solution and Starter Mechanism Question
The axle bolts do not fit the flywheel threads. I checked my CB160 axles and they don't fit either.
No hardware stores around here carrry a 16mm 1.5 pitch bolt.
At the suggestion of jas67 I ordered this puller It arrived lastnight and is exactly what I needed. Thank you jas67!
http://www.amazon.com/BikeMaster-Magnet ... uller+16mm
I know I already have one of these for my CB160's, their flywheel is smaller but the shaft is the same size, but I can't find it.
Starter Clutch Rebuild Question
Do I put any kind of lube on my new rollers? I bought new rollers, caps and springs.
Thank You
Steve
Thank You
Steve
Re: Puller Solution and Starter Mechanism Question
I just put a wee dab of grease on each one just to hold them in place while I get it on the shaft.Steverino wrote:Do I put any kind of lube on my new rollers? I bought new rollers, caps and springs.
