stuck clutch
stuck clutch
Think I already know the answer to this but anyone know of way to free stuck clutch w/o disassembly and individually separating the plates? Know from bad past experience that trying to free up by dumping into gear while running not a good idea.... thanks for any suggestions Kurt
related topic
is there supposed to be a ball bearing between the lifter mechanism and the push rod? I know some bikes have them but I dont have one and dont see on exploded diagram I have.. thanks
Re: related topic
Yes - 5/16 ball in there...
So how did your front hub problem work out? Did you see my pictures?
redtr4 wrote:is there supposed to be a ball bearing between the lifter mechanism and the push rod? I know some bikes have them but I dont have one and dont see on exploded diagram I have.. thanks
Can't shift out of gear
From cold start bike runs fine and shifts for about 8 miles. Then will not shift out of gear or into neutral. HOWEVER, generally once I turn off the ignition, wait a few seconds, it will find neutral. New development is that if I attempt to shift at low rpms it will, but then even that stops working. The entire shifting seems to have become randomly screwed up to the point where I can't offer any better explanation except that I need to do the obvious: bring the bike to normal shifting. The '65 305 is very well cared for, not abused or even ridden hard. I have owned it since 1974. Help is greatly appreciated.
