Frame Tear Down
bweed2112
Frame Tear Down
Post by bweed2112 » Mon Mar 21, 2016 3:01 pm
Hi all,
I am in the process of cleaning up my old 67 Scrambler.
Need to take everything off the frame to get it powder coated.
Currently stuck at taking the front forks, handle bars, ect. off the front.
I know the handlebars themselves can come off really easy, but can't see how the rest come off.
Anybody know how this is accomplished?
Post by G-Man » Mon Mar 21, 2016 4:51 pm
Once you have removed the handlebars, undo all of the fasteners you can see on the alloy top clamp and work from there......
http://images.cmsnl.com/img/partslists/ ... 1_d4a9.gif
bweed2112
Post by bweed2112 » Mon Mar 21, 2016 5:22 pm
 From the diagram all I can see are the 4 bolts for taking the handlebars off (41), the 2 bolts for each strut (35), and the main nut(27).
Am I missing any?
Post by G-Man » Mon Mar 21, 2016 5:51 pm
That's wher you start. After that there is another nut on the stem underneath the top triple clamp.
bweed2112
Post by bweed2112 » Mon Mar 21, 2016 7:04 pm
Thank you for the quick replies. I will use your advice to try again this weekend.
Will let you know if i require further assistance
Post by G-Man » Tue Mar 22, 2016 2:50 am
Try searching for a repair manual. There are some online to download.
DianneB
Post by DianneB » Tue Mar 22, 2016 4:46 am
Make sure you put something under the tree so all the ball bearings don't bounce/roll all over the shop when you separate the stem!
