CL77 FRONT FORKS AND STEERING STEM
I'm just getting started on 2 bikes I've had for 25 years so I'm starting with baby steps. I'm starting with the Forks of 2 CL77'S. Is there a supplier for the internal O-Rings beside original Honda parts? Second question. Has anyone come up with a different bearing system for the steering stem besides the loose bearings used originally.?
There are probably other sources, like ebay, but have you tried CMS?
http://www.cmsnl.com/honda-cl77-scrambl ... partslist/
Re: CL77 FRONT FORKS AND STEERING STEM
You can use the search facility on this site to search for a particular topic or use google.
http://www.honda305.com/forums/taper-st ... 35225.html
PMPiper wrote:I'm just getting started on 2 bikes I've had for 25 years so I'm starting with baby steps. I'm starting with the Forks of 2 CL77'S. Is there a supplier for the internal O-Rings beside original Honda parts? Second question. Has anyone come up with a different bearing system for the steering stem besides the loose bearings used originally.?
